2003 Monte XM Receiver Location
I am putting in Satellite Radio in my 2000 Monte. I have bought the factory mount for the 2003 and wonder where it goes. I know it is in the right side trunk area but have looked and not found a location to fasten it. Anybody have pictures as to it's location?
Rick |
It goes on the wheel well ill try to get you some pix of it in a few
At the top of the wheel well there is a threadd stud sence ur car nvr had xm you may not have this so u may need to just screw it down, i took a pic & tryin to upload it to photobucket, but if u dont have any threaded studs on the wheel well than chances are you dont have the mounts for it
Thanks 03JGMonte.
I will pull the trunk carpet up and have a look. Looking forward to the pictures. |
Heres a few pics sorry it took me awhile
http://i740.photobucket.com/albums/x...e/IMAG0414.jpg http://i740.photobucket.com/albums/x...e/IMAG0412.jpg |
Thanks 03JGMonte for your time and effort getting these pictures. I will look this weekend for this. This site is great because of the efforts by it's member like yourself.
Thanks again. Rick |
Your Welcome, lemme know if you need anymore help
i added a XM system that is an add on to the factory radio. i put the XM box under the center console fit well there and i did not have to run any wires past that point other than the XM antennae to the trunk and up the rear window.
for the XM antenae, i ran mine to the top middle of the back window. my wire fit perfectly under the rubber window trim Alan |
