Factory stereo issues
Not sure if this is the same issue I had, but if it is, there is an orange wire inside of a cluster of wires leading under your interior to the trunk. That orange wire provides power to the amp, so when it splits you will get nothing from it. I would try checking to see if you can find a split somewhere.
