true dual exhaust?
does any body know if it would be possible to make the monte have true dual exhaust instead of spliting in to two mufflers at the end.
RE: true dual exhaust?
anything is possible! but it all comes with a price.
i think your best bet would be a 2.5 or 3" down pipe. thru a high flow cat, then a muffler... and then run toward the back and split the pipes and put the tips on. i think that will give you the best performance and a great deep sound. for you to do true duals you would need to get a set of headers and have a shop cut them up. and then you'll be runing two down pipes... you'd have to make modifications to your O2 system thru and X pipe... i dont think an H pipe will give you the flow needed to register the O2 properly. the prob with true duals is, it doubles the parts needed... you need an extra muffler and cat and sqweezing two down pipes in the space for one... and a 3" will out flow it anyway. |
