TOG Headers....
#191
RE: TOG Headers....
Yah, only the SLP Powerflo Catback..
My TOG headers came a while ago, 28 pounds...
I'm looking forward to coming home and installing those heavy things into my car, hopefully the entire exhaust in one day
My goal, is to start around 7 am and be done by 5 or 6 pm with the entire exhaust system...
Also, I redid a little bit, the way my website is laid out, as far as each individual performance system
i.e. broken down into suspension for poly motor mounts, supercharger for mps, etc...
So if you get a chance, and you are checking back on that site, click refresh, as it will need to be rebooted into your web cache and cookies..
-Keegan
-Keegan
#193
RE: TOG Headers....
yah, Im going to be taking the picture of the 22 boxes of car parts waiting for me at home, and I am having a friend of mine come over around 730 am satuday morning of the 3rd of november to help me install my togs, downpipe, catback, poly mounts, spark plugs, pulley, spark plug wires, etc. He is a huge car nut, and good mechanically, as I also am, so I am hoping it is all a one day event
and luckily that member from clubGP has that write up about the tog headers, so install is going to be a breeze, and I am hoping to have my friend help me to take alot of pictures...
#194
RE: TOG Headers....
Should be a quick install with friends there too. Headers, downpipe and catbackcan be done in about 4 hours. Pulley is about 30 min, plugs and wires can be done with the headers. Polymounts take about 1 hour. So with cleanup you should be able to do it in 6 hours assuming that it's on jack stands in the front.
#195
RE: TOG Headers....
I hope you're right...
I'm still teetering between buying the Pulley Puller, or just renting it..
And I am confused about what the "backing plate" is... ZZP offers it WITH and WITHOUT? Hmm...
#198
RE: TOG Headers....
ORIGINAL: ExplosiveSoundz
Oh, and the other thing, what kind of a jack do you use to get the car up high enough for those jack stands?
#199
RE: TOG Headers....
and the standard floor jack clears the ground effects??
I just emailed zoomer:
__________________________________________________ ___
---Custom Service Replied---
You are correct in all points.
-----Original Message-----
Sent: Tuesday, October 09, 2007 6:58 AM
To: Customer Service
Subject: Backing Plate?
Hey,
I recently purchased your ZZP MPS, and am now going to be purchasing the
Pulley Puller Tool, to keep.
Correct me if I am wrong:
I am going to use puller tool to pull stock pulley.
I will then use the system to press the new mps mounting hub onto the
snout.
I should ONLY need the BACKING PLATE if I wish to Remove the MPS
mounting hub in order to do maintenance on the blower, correct?
Thanks in advance!
-Keegan
Hey,
snout.
Thanks in advance!
-Keegan
#200
RE: TOG Headers....
Thinking back about it I think I just got mine at Walmart shortly after my divorce.... wasn't thinking too clearly back then.
