SLP Cold Air Intake on 3400 and Airbox 3400 vs 3800
I have a 04 monte with 3400 and i really want the SLP intake (im aware of wizaired and zzp i just cant fork out that kinda cash). anyway ive seen them on 3400s:http://oi40.tinypic.com/r8gv47.jpg
but i just emailed SLP to double check that slp21039 will work here was their reply: Our cold air does not fit a monte carlo with a 3400. Someone may have mods to make it fit however we have never done it. Regards, joey What do you guys think? Has anyone run the slp intake (21039) on their 3400 montes? If so is there any moding involved? If no one than does anyone know if the air box on the 3400 and 3800 are exactly the same because if so then the slp intake should fit on a 3400 right? |
Typically the problem is that the MAF sensor is IN the intake tubing for the 3400 and the 3800 it is in the TB, so the boxes don't have to worry about that.
If you can't fork out the money for the wizaired, perhaps look into creating your own? |
i follow
(Post 411218)
The SLP box isn't really that great. You should definitely save up for a wizaired in my opinion.
You could buy a used air filter box and make your own. that way you are not out a lot of money and modify it to a cold air and use a k&n filter they are more user friendly and this way the maf stays were it is just idea
I'm in the same boat I'm looking for an intake for a 3400 and from what I see wizaired is the best any one have a part number off hand for it?
zzperformace.com
go to grand prix and intakes, then make sure you select the 3400 |
So the grand prix's are the same as the montes with the 3400's?
Yes the Grand Prix is a W-Body just like the Monte and many parts are similar
Another option is gut your existing air box to open it up for more air intake....
