RESONATOR DELETE
Anyone replace the resonator with a glasspack or straight pipe? I was wondering if anyone had tips on how to go about doing it by oneself without welding. I was thinking a sawzall for taking the ****er off and than just bolting on straight pipe or a glasspack. Anyone got any reccomendations on what I should replace it with?
RE: RESONATOR DELETE
straight piece of exhaust pipe is all i have, mine was done at a mufflershop, but you could probably do it yourself, just measure the length you need, then buy 2 adapters for each end to go over each end and then 2 clamps for each end of the pipe
thats all you really need, and if you can do it in stainless all the better :) let us know what you think of the sound, because you got the u-bend delete, highflow cat and if you get rid of the resonator you will have the same as me, and i love the sound |
well the ubend/highflow cat is sitting in my den right now. Upon trying to install it, I broke a sleeved socket and an adapter on a wrench lol. Third times a charm tho, and i will post sound clips once I get them both done.
it cant be much to have a shop weld it in. like 20 at most! clamp it up then get it welded. then you wont have to worry about it coming loose.
