Removing crosspipe
So if I remove my cross pipe can I put it right back on without any gaskets needed? It wont ruin anything that I would have to replace before reinstalling?
Edit: My bonneville has the same engine and I wanna wrap the crosspipe to stop some heat from getting to the throttle body. Thanks. |
If all you're going to do is wrap it, I'd just leave it in place. Not worth the potential for leaks or screwing with rusted out bolts.
Realistically, it already has a heat shield on it from the factory so I wouldn't think you'd have any measurable gains from wrapping it. I will admit that I used to have one of those throttle body heat shields (granted that was with uncoated headers), but I couldn't see any difference with it on or off. Personally, id rather put that money towards a set of headers. |
(Post 702605)
Realistically, it already has a heat shield on it from the factory so I wouldn't think you'd have any measurable gains from wrapping it. I will admit that I used to have one of those throttle body heat shields (granted that was with uncoated headers), but I couldn't see any difference with it on or off. Personally, id rather put that money towards a set of headers. Its just my bonneville doesnt have the heat shield like the monte does... Same 3800 motor and all.... idk, thanks tho. Would have done it and possibly end up with a headache. |
Hmm, never realized they made some without the shield.
it's really not terrible to take off, but I've just run into a few different issues: -breaking a stud/bolt (common to any exhaust related work) -previous owner/shop way over tightened it and screwed up the mating surfaces (if you then torque it correctly, it leaks. If you over torque it yourself, you risk breaking the studs). I get that sometimes its unavoidable to have to remove it, but in this case you could save a lot of potential headache by just wrapping them in place. Maybe I've just been burned too many times (no pun intended) on exhaust issues. |
