Powerlog installation
I have just installed a ZZP PCM, Wizaired CAI, ZZP 3" downpipe (Stainless) w/High flow cat, Resonator removed, Autolite 104 plugs and a 180 drilled t-stat. Next I'll go to either a 3.4 or 3.5 pulley swap and I'm contemplating a cat back system (Not sure which yet) and a Power log front manifold. The pulley and catback I can easily do but after taking a close look at the room under the hood around the front manifold I'm thinking oh boy this doesn't look like an easy job. Those of you who have done it would you chime in and let me know what I'm in for if I attempt it and any pointers you may have would be great.
RE: Powerlog installation
i dont know if it would be any different for the SC3800 but for my NA it was a piece of cake i had more than enough room to get it in to position.
The hardest part for me was getting to the old one out. I would recomend taking off the heatshield first if that is even possible(not sure if it is) and then taking out the manifold. because when i was doing mine the heat shield was the only thing that would catch on stuff and get stuck in the way. i really is not that hard to do. Good luck |
ORIGINAL: Submariner I have just installed a ZZP PCM, Wizaired CAI, ZZP 3" downpipe (Stainless) w/High flow cat, Resonator removed, Autolite 104 plugs and a 180 drilled t-stat. Next I'll go to either a 3.4 or 3.5 pulley swap I can easily do but after taking a close look at the room under the hood around the front manifold I'm thinking oh boy this doesn't look like an easy job. Probably one of the easiest installs- shouldn't take more than 20 minutes. |
Now that I've looked closer I agree it doesn't look as tough as I originally thought. As soon as ZZP gives me the PCM and Cat credit I'll order the PLOG (Stainless w/ceramic coating).
