newbie to exhaust..
I am looking for an exhaust or parts to make my exhaust sound better than factory and get a little power out of it also...
Soo many options and things to choose from with different sounds What exactly is a ubend delete and a resonator? I heard that combination makes for a nice sound. I appreciate the help :thumbsup: |
The U-bend is where the factory "bent" the exhaust pipe right after the cat (it looks like a U). The purpose of this is to allow the O2 sensor to sit veritcally. There has been some discussion if this is an obstruction or not. What I understand is regardless if you have a U-bend or delete it, the volume of exhaust moved through that section is virtually the same either way (again, this is from what I understand, not saying it's 100% true, having the U-bend deleted is definately a nicer look).
A resonator is "like" a muffler, used to change the tone of the exhaust. You can see it directly after the U-bend. Mine was replaced due to the seam rotting away and creating a bad exhaust leak. Then I had problems with the after market replacements blowing out baffles in them to the point now, I had the res deleted and will NEVER turn back. Some people feel the exhaust sounds "drony" without the res, in my case, i believe it opened the exhaust up and to me it sounds great. My exhaust is all stock EXCEPT: - ZZP PLOG to replace the front manifold - ZZP 2.5" downpipe with high flow cat and u-bend delete - Resonator Delete The rest is stock mufflers and Y pipe. Here's a link to my web site about my ZZP downpipe install AND comparison to the stock one: '04 Monte Carlo SS - ZZP Downpipe There are LOTS of other exhaust options out there and they depend on what you want to achieve. From what I understood, the stock mufflers and Y pipe are not much of a restriction in these cars. |
Ok. So if delete the resonator or get a different resonator it will change the sound and I wont have to do anything else?
like a zzp or magnaflow resonator? how bout the catalytic convertor? I dont wanna have a deep obnoxious sound, i wanna have a nice tone that wont cost me a arm and a leg. |
