New Custom Fenderwell Intake! Pics!
I am so mad that I typed this thread and submitted it and it says page cannot be found lol. Anyways I got bored and decided to make a new fenderwell intake.
http://img815.imageshack.us/img815/3389/img0098ij.jpg In the picture above is my old black plastic duct and my new aluminum duct. Also in the picture is fiberglass insulation, k&n air filter, and aluminum tape. As you can see I started wrapping the insulation around the aluminum duct and secured it with aluminum tape. http://img11.imageshack.us/img11/2174/img0099oha.jpg It took a while but I finally finished. I had to quit about 3 times :rotfl: http://img210.imageshack.us/img210/7636/img0100kr.jpg Next I started wrapping the insulation in aluminum tape to make it look a little better. Heres a pic with the k&n air filter installed. http://img221.imageshack.us/img221/2749/img0103zu.jpg After a lot of yawning and swearing I made it half way. I gave up again for a few minutes and said I have nothing better to do so I went back lol http://img607.imageshack.us/img607/3759/img0104xh.jpg I finally achieved what I wanted to do! It was way longer than my original plastic duct so I had to remove some insulation and push some in... http://img651.imageshack.us/img651/9301/img0101hah.jpg I had plenty of insulation left and tape so I decided to insulate the stock air sensor holder thingy also to get all of my money out of it. Poked a hole in the insulation for the sensor. http://img190.imageshack.us/img190/4559/img0102vk.jpg Heres a picture of the stock air thingy on the tb with the sensor attached. Looks tacky huh? lol. Im so glad that you cant see the coolant leaking on top of my tranny :rotfl: http://img20.imageshack.us/img20/2770/img0105mf.jpg I got the fenderwell intake all mounted up at the bottom using tie-wraps. I used extra just in case some break. http://img688.imageshack.us/img688/8146/img0106mb.jpg Im making progress, heres a snapshot of the intake installed. :thumbsup: http://img705.imageshack.us/img705/750/img0107pk.jpg So I then attached the two parts and decided to insulate the connector thingys also to make it look like 1 unit. http://img845.imageshack.us/img845/7121/img0108as.jpg Heres my finished product! Its not the best looking fenderwell in the world but it does its job. Idle seems to be the same but when driving 30-60mph it doesnt bog as much as it did with the old fenderwell. |
Hahaha, good job man.
That's definitely insulated well. Didn't want to use piping/tubing for a 'straighter' result? |
Originally Posted by Jomao_o
(Post 415838)
Really?
(Post 415838)
Originally Posted by MJClemm
(Post 415870)
Hi, does this work? LolLol
:rotfl::rotfl::rotfl::rotfl::rotfl::rotfl:
LMFAO man you have a good imagination I'll give you that much bro. post dyno numbers of before and after installation. |
(Post 415870)
What his homemade intake? Sure, you have to make it as straight as possible for efficiency. Most people use tubing from hardware store. |
(Post 415886)
Originally Posted by Habbibie
(Post 415881)
O.O
You should wrap the throttle body. |
