Looking into downpipe.
the 2.5" is plenty big and recommended for NA applications. the 3" ones are for S/C applications. the pipe will throw a cat efficiency code or something similar. nothing is actually wrong, there's just lots more flow there so the ecu thinks there is something wrong. people usually tune this code out with a custom tune or a canned pcm from ZZP and have no problems as far the the DP goes. overall, it's a good mod that many would recommend. there are many past discussions on this topic that can be accessed via the search tool.
Offroad pipe means no cat. I would recommend getting the 2.5" 304 stainless steel bolt-in with cat.
The only way you would need a new 02 sensor is if your current one got fried into the downpipe and a shop is replacing it for you and won't let you leave without the 02 sensor haha
if you deleteing the rear 02 sensor in the pcm you do not need new 02 sensor for the back one if that's what you asking .
I would recommend the cat for a few reasons. One emissions, two it's illegal not to have a cat, and NEVER do an open exhaust on the downpipe on our engines, it will sound HORRRIBLE
