Intake?
I have a 2000 monte ls 3400, and I'm looking for an intake(preferably k&n) but I cant find anyhting, I dont want to go with custom, does anyone know where to find one?
RE: Intake?
build your own is about all you can do... don't know of any GOOD cai's for the 3400. somebody else can post on how to build a fenderwell intake for you.
RE: Intake?
i'm still trying to figure out if we can make the k&n unit work, one of my friends, also a member on here has a 3.4l and we're taking a look and the only difference we can see is the maf sensor is in the middle of the intake tube on the 3.4 instead of @ the throttle body on the 3.8 so we're seing if it can be moved to the throttle body and then install the cai
RE: Intake?
Simple solution: I was looking for cold air for my 3.4L as well and couldn't find anything for a 3.4 Monte Carlo. I was about to settle on buying an SS cold air intake and modifying it when I changed tactics. I found a stainless steel cold air intake for a 2001 Oldsmobile Alero that uses the same 3.4L V-6 as the Monte Carlo and has virtually the same engine compartment layout. Picked it up for $35 and just slapped a 9" K&N filter on the end.
RE: Intake?
i was looking around ebay and found this
http://cgi.ebay.com/ebaymotors/99-05...spagenameZWDVW looks decent but would it even fit? |
RE: Intake?
Me and wizz kid are trying to figure this out if it works we will post pics and how we did this
RE: Intake?
thanks alot, get back to me when you figure it out
RE: Intake?
its funny, i had the same problem, but i went to the import lot of bucks auto, and i found this intake tube (stock) off of a volvo i believe, and it worked perfect torun my filter in the bumpercover, i'll post a pic tomorrow.
2001 ls v6 3400/3.4l cai
Hi. I'm looking for a cold air intake for our 2001 LS 3400. Many of the threads I've read have mentioned air boxes from K&N, WizAired (ZZPerformance), and Cold Air Induction as being installed on a 3400. But, I've talked to K&N and ZZPerformance. Neither have an intake box for the 2001 3400. I'm waiting for a response from CAI. Were products for the 2001 3400 discontinued? Or do people buy the kit for the 3800 and make it fit? I don't want to make a custom box if I don't have to.
Originally Posted by wiz kidd
(Post 90344)
