HELP:::Whats the easiest way....
to put full tube headers on a 1986 monte...g body of course...lift the motor?
RE: HELP:::Whats the easiest way....
when i had my 80 i had to life the motor just enough to get them to clear.
But i have helped a frend and his slid in. so it would depend on what your trying to go around. Good luck |
yup you have to lift the motor and havin' a helping hand don't hurt
the passenger side went on pretty easy with removing the motor mount and the starter..now the driver side is a bitch...so tight...do i have to remove the steering rod?
are you going from the top or the bottom on them? LOL
after lifting the motor i never removed the starter on mine. the Drivers side you can sometimes lift it high enough to clear other wise start taking the rag gear apart |
