RE: Cold Air Intake Materials
ok so i want an intake and read up on the silly SRI sucking hot air in. whats the name ofthe material needed? like the flexible tubing what section would i find it in? i work at Lowe's :D.
10% off :D |
funny i have a cold air intake for the mustang that vi have never had a heat issue with the intake it allways felt cold to the tuch only when it got hot is when waiting at a red light waiting to turn in to get my 7th gen monte still have the mustang use the monte as a primary but switch meatel is good never had a heat problem
Look in the plumbing department. Many use PVC or ABS for a rigid intake piping, and black sewer pipe for flexible intake.
funny i have a cold air intake for the mustang that vi have never had a heat issue with the intake it allways felt cold to the tuch only when it got hot is when waiting at a red light It may feel cool with the hood open when you're touching it, but imagine when you close the hood- the filter is sucking a lot of its air from your radiator exit air coming from the fans, and also sucking heated air from off the exhaust crossover at lights w/ the fans off. Actual IAT's are a usually good bit higher with a HAI compared to a FWI/CAI box. |
thats what i was implying
