cold air intake ecm placement?
hey guys i just bought a Wapon dragon R intake kit for my 03 monte carlo SS 3.8L engine and when i removed the old intake box the ecm was in there and on the paper it says to let it hang around the engine but i dont know where to put it now that the box is removed. should i leave it hanging like it is on the bottom of where the box used to be or is there another solution?
FYI - Unless you have a shielded box around that Weapon-R intake, it's known as a HAI (Hot Air Intake) as it will suck in the air around the engine that has been warmed up.
As for your question about the PCM, I would recommend securing it. Many intake kits, like a Wizaird, come with a method to "strap" the PCM down. Chibiblacksheep is in the middle of some mods with his Monte, as a result he actually mounted the PCM tray from I believe a Blazer (or another GM truck) in the location that the PCM sits in.
Allowing the PCM long term to "flop around", you run the risk of damaging the wiring and/or the PCM.
seanpeezy
01-10-2016 04:05 PM
siouxcity04montess
06-05-2010 05:49 PM
