please help ping identification
Old 02-21-2010, 07:11 PM
mak330's Avatar
Default please help ping identification
ok so i made this great blueprint of an exhaust and pinpointed where the ping noise is coming from. it happens when im at a stoplight and drive threws. it also happens when i turn the car off. it happens every 10 to 20 seconds. and b4 anyone says i ran it really hard, it happens every time. thankyou
Old 02-21-2010, 07:12 PM
mak330's Avatar
so my question is what is that part???
Old 02-21-2010, 07:19 PM
That's the resonator!
Old 02-21-2010, 07:35 PM
mak330's Avatar
do those get clogged? how much does one cost?
Old 02-21-2010, 07:57 PM
Old 02-21-2010, 07:59 PM
No way will a resonator get plugged up to impede exhaust flow- they're designed similar to a glasspack- a big wide open tube about the same size as your exhaust piping with a bigger outer shell and dampening material inside.
The thing in front of that- the cat gets pretty hot and can get clogged. because its more of a honeycomb mesh design.
My cars ping when they're cooling down too I always just figured it was the cat. Not real sure what exhactly causes it though.
This is what most look like inside:
This is what the inside of the cat looks like:
Obviously nothing is going to make it through the cat big enough to get lodged in the resonator. As far as getting plugged up from carbon- if the holes in the resonator get plugged, the exhaust note will change (because by not letting air in the outer chamber esentially would be like deleting it with a piece of straight pipe), but its not going to stop exhaust flow- and I don't see how it would cause pinging.
Old 02-21-2010, 08:07 PM
mak330's Avatar
thanks well i never had this problem till i got a new exhaust like 4 months ago, from the dealer.
du dun dunnn
my old one was rusted.
so anyways im not sure if they messed up the install or what.
anyways the goodwrench place i use to take it to closed, and my warrantys up.
i understand it should ping very quietly, but this is loud and embarasing, and when the car is on.
it deffinatly sounds like its coming from the resonator.
so its a bolt on, no welding involved. or should i take it to a muffler shop.
i want to run duals anyways, not sure if i should just wait it out or fix it.
Old 02-21-2010, 09:22 PM
It's interior can become dislodge and rattle due to the exhaust gases flowing through it, causing the noises. BTW, I've seen a clogged resonator (believe it or not) due to a cat busting it's innards and the guts getting hung at the res. The res and cat would glow cherry red when the engine WAS able to run.
Old 02-21-2010, 09:40 PM
mak330's Avatar
its really not that bad, but i know its not right. i just dont know any good muffler shops around my area. i used to go to one but they closed up due to the economy. so are there welds on my exhaust or is it all bolts and clamps. my buddys got a lift at his dads. maybe ill mess with it there. he can weld.
still not sure i might just rip it all of and go magnaflow on everything. i hate to waste a 4 month old exhaust but its obviously junk anyways. its still shiney lol. and it costed GM about 800$. lol wish i could have talked the tech into ordering me a proformance cat back for that price.
Old 02-21-2010, 11:48 PM
That would suck!
The whole catback is bolted on at the rear of the cat- between it and the resonator. Maybe you could unbolt that connection, drop the catback down and see if you can see anything- maybe a weld is coming apart or something- I can't think of anything that would cause a very loud ping every 10 seconds or so.
Quick Reply: please help ping identification
