When you car is at operating temperature.............
Old Jun 6, 2005 | 03:37 AM
04MonteLS's Avatar
Default When you car is at operating temperature.............
where does the needle sit at? Mine sits at the first line under the halfway point.
Old Jun 6, 2005 | 05:47 AM
mickey's Avatar
Default RE: When you car is at operating temperature.............
Really? wow mine dont even come half way to the center mark more like between 180 and ? if looking atthe dial it would be about 9:00 on it
think the only time i have seen mine get that high is when i was sitting in teh hot sn on a 80 deg. day waiting for a stau. to get over with the A/C on.
Old Jun 6, 2005 | 05:51 AM
04MonteLS's Avatar
ORIGINAL: mickey
on my dial, 9 is the halfway point, you have a SS right?
Old Jun 6, 2005 | 06:01 AM
mickey's Avatar
yup. but i would tink they would run cooler in yours guess not.
DID I MENTION I HATE FLOOD CONTROLL!!!!!!!!!!!!!!
Old Jun 6, 2005 | 06:04 AM
04MonteLS's Avatar
ORIGINAL: mickey
I'm just thinking the layout of the dials are different
Old Jun 6, 2005 | 06:10 AM
mickey's Avatar
not sure on tha i have never been inside of a ls model nor have i seen a pic of the dash . but mine has the factory SS style guages even my spped hut over lay has the same lay out
Old Jun 6, 2005 | 06:16 AM
04MonteLS's Avatar
ORIGINAL: mickey
then from what I see, if you say yours is at the 9 o clock position, that's 140 degrees, the lowest it goes.
Old Jun 6, 2005 | 06:20 AM
mickey's Avatar
had to go look lol
but yeah between 140 and 180
never makes it to the center lin on mine unless eal hot out side like above 80deg. and im divign alot
Old Jun 6, 2005 | 06:22 AM
04MonteLS's Avatar
ORIGINAL: mickey
had to go look lol
LMAO
I hope a cooler stat helps me
Old Jun 6, 2005 | 06:26 AM
mickey's Avatar
it should bring your temp down some if you get a 140 the car will normally run at 140 unless there is asomethign else you are dealing with that you dont know about right now.
But somthign to look at is if your adding alot of water to it (everey week or so)
or if you have oil in the water or water in the oil you might have a head gasket goign out on ya.
jsut watch it and your more then likly going to be good with that lower temp stat
