-   General Monte Carlo Talk (https://montecarloforum.com/forum/general-monte-carlo-talk-9/)
-   -   Weird Problem going on with my A/C Compressor Cutting on (https://montecarloforum.com/forum/general-monte-carlo-talk-9/weird-problem-going-my-c-compressor-cutting-10730/)
motivation2k3 Sep 27, 2008 03:12 PM
I have a 2000 chevy monte carlo pace car and i have a weird problem with my a/c compressor. It wont cut on unless i put a paper clip in place of where the fuse usually would be at and thats the only way it will cut on. the fuse isnt bad , because i tested it, but the fuse wont cut the compressor on though, but the paper clip works for some strange reason. but its a weird problem and i was wondering if any of u have any suggestions?
Space Sep 27, 2008 04:20 PM
RE: Weird Problem going on with my A/C Compressor Cutting on
[align=center]Hi `Eric,[/align][align=center]I don`t know `if I would be using a paper clip to bypass[/align][align=center]the protection of your fuse. It could overload other componets[/align][align=center]& fry them [X(].[/align][align=center]I would check your relay.[/align][align=center][:-][/align][align=center]Compressor clutch is controlled by the PCM through the relay.[/align][align=center][/align][align=center]Test your relay & see `if its `ok. [/align][align=center][/align][align=center][:-]Location [:-][/align][align=center][/align][align=center][/align][align=center]Clutch coil diode is 10 cm from the plug, the cycling switch is in the A/C line at lower left front of engine compartment, rely is in the bottom of underhood electrical center. [/align][align=center][/align][align=center][:-]
http://www.2carpros.com/forum/automo..._Pres_Sw_1.jpg[/align][align=center][/align][align=center]:eek:From `SpaceReSearchDept[/align][align=center][/align][align=center][/align][align=center][/align][align=center]Good Luck `Eric[/align][/align]
ChucksMonte Sep 29, 2008 03:58 PM
have your A/C system pressure tested and make sure its not low on freon. it sounds almost like the pressure switch isnt letting it go on. Have you tried a new fuse...i know the one you have is ok but maybe its not just right. Id try a new fuse of the same amprage and get the system checked out by a mechanic. Sticking a paperclip in there is doing nothing good for the system thats for sure.
