Water sloshing in driver's door after heavy rain
stupid question, I have same problem with my 01 SS, water sloshing in door after heavy rain, your idea of drilling hole seems ideal solution-the question is (and now think blonde) how do I locate "LOWEST part of Door where water could pool"? isn't door bottom all the same "height"?
Open the door completely, look along the bottom and pull back on the weather stripping. You'll see the current drain holes there, and if you want to drill and widen them, you will see the holes to start with.
thank you for your help. I went out to look at bottom of door and see the seal you are talking about, you said pull it out of way and i will see holes, ok but how does the seal come out so that you can put it back when you are through?
The Weather Strip at the edge of the door and window must be deteriorated and may need to be replaced so the water will not infiltrate the door. Check with a local body shop to see if they can repair it.
Motorhead
Apr 25, 2018 08:08 AM
mstrmysterious63
Apr 18, 2018 04:46 PM
ronipooh
Jul 18, 2011 12:13 PM
