Should I buy?
I have an opportunity to buy a 2001 LS with 244000 miles on it. Should I consider buying this? I know I will have to do some work to it but would like to get a Monte Carlo and this will be a very cheap price to get into one. Any advice or opinions would be appreciated. Thanks. |
Originally Posted by Al Sleet
(Post 715524)
I have an opportunity to buy a 2001 LS with 244000 miles on it. Should I consider buying this? I know I will have to do some work to it but would like to get a Monte Carlo and this will be a very cheap price to get into one. Any advice or opinions would be appreciated. Thanks. So the previous drivers will have alot to do with how the Car functions. Some of this stuff will show up in the test drive? Check the Trans fluid to see if it is Red or Brown (Red is good) check the oil to see if it has been changed, how clean the engine bay tells you if its had proper maintenance. Finally the brakes check the rotors for grooves, and the pads for depth. Good luck :) |
Mileage is way too high IMO, there's no life left. Itll just be constantly putting more money in than the car is worth to keep it on the road.
What would you like to do with it? Drive it? or build it for collector?
