Need help
I was driving my 2007 monte Carlo ss yesterday about 65 mph and it just died. Didn't hesitate or sputter like it was out of gas but it was low. And it it wouldn't start back up. It was just turning over. Battery seems to be fine. It's turning over at a normal speed but it won't crank. There is fuel in the rail.
What's the car's mileage? Did you check the alternator specifically?
Any check engine light on before shut down? If not did you check fuel pressure with key on? If so what psi is it if not I'd start there.
(Post 720383)
Originally Posted by Steelbizkit
(Post 720389)
Originally Posted by Denarius23
(Post 720402)
No check engine lights. I checked for fuel in the rail by the pressure valve. There is fuel in the line but how much pressure im not sure. My remote start still works so there are currently no check engine lights
Rent a fuel pressure tester from oreilly or autozone. If psi is to low you can have fuel but injectors will not fire fuel. Cant remember what the psi should be with key on/engine off but should be higher than 45 i think. |
(Post 720382)
My remote start still works |
(Post 720396)
The mileage is around 132000. The alternator seemed fine.
(1) Battery (including a bad battery connection or bad battery cables) > I can say it's amazing that what looks like a good battery connection can actually be the complete opposite and it's amazing how little corrosion can whack things up. It's always a good rule of thumb to start with the battery to assure you have good connections. Undo the positive and negative cables at the battery terminals, wire brush and apply cleaner to both the terminals and cable contacts and reinstall with some sealer to help assure a good connection and stop (or slow) corrosion from building up. It's also a good rule of thumb to keep the top of the battery clean because any dirt or debris around the terminals can slowly become conductive over time and that can actually drain the battery. I used to have occasional battery issues that slowly got worse over a several year period - it ended up being excessive corrosion and wear on the negative cable contact so the battery wasn't able to receive a proper charge when the car was on (and, yes, even with how meticulously clean I keep mine it was still an issue). (2) Alternator (3) Fuel pump > Do you hear a buzzing sound upon your attempts to start? That buzzing sound is the fuel pump and if you don't hear it, it's probably not pumping. If those have been confirmed okay, then there's also: (4) Ignition system (5) Speed system (6) MAP sensor (air/fuel ratio) |
