HELP: Seventh Generation Monte Carlos "TRUNK Dimensions" ?
Old 07-31-2011, 02:38 AM
tremayne0126's Avatar
Question HELP: Seventh Generation Monte Carlos "TRUNK Dimensions" ?
Can anyone with a 7th gen get me the trunk dimensions the basic Width x Height x Depth
Thank You for any HELP
Last edited by Space; 07-31-2011 at 06:11 AM. Reason: Change title to get noticed : ) I Hope : )
Old 07-31-2011, 06:13 AM
Below is all that I could find , (not much help),but hopefully one of our knowledgeable member's can assist...Good Luck
2007 Chevrolet Monte Carlo Specs: 2 Door Coupe LT Dimensions
Cargo Area Dimensions. Trunk Volume (ft³) 15.8. See all 3 Trims. Gallery. Photos (103); Videos (21); 360° View. 2007 Chevrolet Monte Carlo 2-door Coupe SS ...
Old 07-31-2011, 11:26 AM
i saw that but its not specific enough thanks alot though ill square off 15.8 and see if this helps
Old 07-31-2011, 11:35 AM
Just curious Are you putting in a SuperBad `Big Audio System ? or making the rear section in2 a BED
Check back later, several of our member's have put major big speakers in the back & may not log on2 the MCF 2day...
Let us know what you are planning ? Or is it a surprise
Good Luck on your Project
Old 07-31-2011, 11:39 AM
xxtheshockerxx's Avatar
RED DEVIL
without taking a tape measure out in the garage...idk
Old 07-31-2011, 06:12 PM
big audio, i got 6 12" l5 kickers coming but thinking of sending them back for 4 l7 15" my monte is on the way from NJ so i need the inf before hand
Old 07-31-2011, 06:17 PM
see i know the 6 12s will fit just by using 2 boxes holding 3 12s each measured at w40 h14 l4 all that will fit but for 4 15s judging from the 2002 monte i had if the trunk didnt get a at least 1-2inches higher then 4 15s wont work because by pushing them back they will just hit the rear deck 6x9s and stop. so for im doing my homework but without the measurements ill just be waiting 2 weeks for my car
GreenEyedMonte
07-18-2019 04:49 PM
MONTE DOM
02-12-2013 03:53 PM
02 Earnhardt Monte Carlo SS
12-18-2011 06:18 PM
86 luxury sport
06-06-2011 02:41 AM
brettmonte
06-05-2010 10:12 PM
Quick Reply: HELP: Seventh Generation Monte Carlos "TRUNK Dimensions" ?
