Map Sensor Connector
So I was replacing my PCV Valve and managed to break one of the connectors on the Map Sensor deal. The sensor is fine, its that little part it plugs into and then its got the two prongs coming up that the map sensor locks into. I'm not worried short term, one prong seems to be holding it just fine (unless a ton of pressure is going up into the sensor- I don't know much about engines) but long term I would like to replace it. I checked GMPartsDirect but all I see is the sensor itself. Is there no way to buy just this little plastic part?!
Thanks |
