getting low fuel millage
Old May 16, 2008 | 04:11 PM
sprfrk2005's Avatar
Default getting low fuel millage
Alright guys here the thing i own a 01 monte carlo 3800 and for some odd reason i am only getting about 200 miles per tank city driving and i have not idea why. I just got the oil changed and spark plugs put in. About two days ago i sea foamed the car. And for some reason my gas gauge keeps going up and down up and down. The mods i got on my car would be CAI, throttle body spacer, and MSD wires. Can anyone help me out with what could be the prob. damn gas prices are crazy.....
Old May 16, 2008 | 04:34 PM
Cowboy6622's Avatar
Default RE: getting low fuel millage
how many miles are on the car? it could just be getting old... my parents have a 43 gallon tank in their suburban with 254000 miles and it gets about 450 miles to tank if it's really lucky (something like 12 mpg, used to get 16 on a bad day). might be getting old. is it running smooth? no gas leaks anywhere? maybe it's leaking somewhere.
Old May 16, 2008 | 04:53 PM
sprfrk2005's Avatar
car has about 85k and nope no gas leaks anywhere i puzzled by this. car runs smooth and idel smooth. only mechanical work done to this car is had to take my car to get the valve machined because it wasnt giving me compresion on piston #5 but thats about it engine wise... had power stearing pump replaced three times
Old May 16, 2008 | 06:56 PM
Cowboy6622's Avatar
hm... one cylinder wasn't giving compression so a valve was machined... okay, not a biggie, but usally the cylinders wear evenly. you said valve.. did you mean valves or was just the one valve machined? usually if one cylinder gets worn down and isn't getting compression the rest are only a good several thousand miles behind it.
Old May 16, 2008 | 07:03 PM
sprfrk2005's Avatar
well they machined the back valves..... when they did that they changed plugs and all spark plugs were down to nothing
Old May 16, 2008 | 07:50 PM
rysZ34's Avatar
check a clogged fuel filter and for an intake leak.
Old May 16, 2008 | 08:16 PM
sprfrk2005's Avatar
how would you check for an intake leak?
Old May 16, 2008 | 09:34 PM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
Have you tried changing gas stations? I heard some of them were mixing in the corn fuel and selling it as regular even though it's illegal. They make more and you get less mpg.
Old May 22, 2008 | 04:38 PM
saigashooter's Avatar
Could also be the spark plugs, I used to have a Chevy Blazer, and those trucks hate Bosch plugs with a passion, poor economy and misfires were common with them.
Old May 22, 2008 | 04:51 PM
Hi Ozzy,
Sorry that you are getting lower MPG's : (
How much lower MPG are you getting from your past MPG ?
Are you running your A/C ?
Is you air filter super clean on your CAI, if it's dirty it can affect the
Mass Air Flow Sensor & increase fuel volumes ?
Do you have all your tires inflated to proper Inflation.
A few pounds less can lower your MPG : (
Are you a aggressive driver ?
Look forward to your answers & hopefully a resolve
to your problems.
Good Luck,...from `Space
