Fuel tank?
How large is it? how many gallons does it hold? I'm curious because I'll be taking a trip to PA (about 360 miles) and trying to google maps how many gas station stops I'll need to make.
RE: Fuel tank?
fill it up once at each end and it should make it.
it is a 17 gallon tank... but that don't mean the pickup tube will pick up that much of it. plus, your computers MPG rating may be a little off. However, if you top off before leaving and fill up at the other end, I think you'll be just fine :) |
RE: Fuel tank?
ORIGINAL: Cowboy6622 fill it up once at each end and it should make it. it is a 17 gallon tank... but that don't mean the pickup tube will pick up that much of it. plus, your computers MPG rating may be a little off. However, if you top off before leaving and fill up at the other end, I think you'll be just fine :) |
RE: Fuel tank?
i believe my owners manual says 17... but edmunds may be right. but again, that don't mean the pickup tube will pick it all up. Our Honda Odyssey has a 21 gallon tank and we learned the hard way it only picks up 19.2 gallons of it.
RE: Fuel tank?
The route I took to get to my destination in PA ended up being a little over 400 miles, and I made it on one tank (which was awesome because gas was almost a quarter cheaper in PA than in MA). It was a nice trip, the car did fantastic, no issues whatsoever. :D
RE: Fuel tank?
yay for saving money :) told you you could make it ;)
