03 monte ss to 02 02 monte moon roof conversion
Old 10-06-2018, 11:03 AM
Kenny Guido Temprano's Avatar
Default 03 monte ss to 02 monte moon roof conversion
OK, I have a wrecked 03 ss which ive been swapping to an regular 02 monte. things are wrapping up but by 03 ss has a moon roof and my 02 has none. my question is, what type of trouble would I run into if I decide to make the 02 a factory moon roof?
Old 10-11-2018, 03:07 PM
anybody?
Old 10-11-2018, 09:41 PM
I'm not sure anyone has done this task on one of these cars. I've seen people do it on other cars (heck saw an amazing body job of a guy swapping a modern sunroof that was like 3 pieces of glass and when open almost the entire roof was open, he put that on an 80's G-body). I have also seen stuff where people swapped T-Top roof panels on 80's F-body cars. My guess would be that you would have to do the following:
- Remove the headlines from both vehicles. Take care disconnecting the wiring harness in the roof.
- For safety, remove the sun roof assembly from the one car.
- Find the factory weld points for the actual roof metal, drill out the welds.
- Swap the roof panel (whole piece) to the non-sunroof car. Re-weld it in.
- Paint the new roof to match it's new car.
- Re-install the sun roof assembly.
- Re-install the sunroof headliner (using the wiring harness that is glued on it).
If you try simply cutting a hole in the roof instead of swapping the actual metal roof, you will probably have a ton of problems getting a factory roof piece installed and everything lining up. Another option, get an aftermarket sun roof kit.
Jester_20
04-03-2011 08:52 AM
steve tomlinson
09-08-2010 10:44 PM
WreckedSS
09-18-2009 09:02 PM
ss loulou
07-14-2009 10:05 PM
mavrickf1613
10-25-2008 06:59 PM
Quick Reply: 03 monte ss to 02 02 monte moon roof conversion
