-   General Monte Carlo Talk (https://montecarloforum.com/forum/general-monte-carlo-talk-9/)
-   -   FOG LIGHTS (https://montecarloforum.com/forum/general-monte-carlo-talk-9/fog-lights-7927/)
07MONTECARLO666 Feb 13, 2008 10:53 PM
FOG LIGHTS
hey i was woundering if fog lights of a 07 ss would go into a 07 lt...would the wiring would work the same and have the same setupso basicly if i could just put them right in
[IMG]local://upfiles/3722/3EB621587D374127BCDC2F4A228E1578.jpg[/IMG]
[IMG]local://upfiles/3722/1CFC78DC7F3C4009ADBAE13C01CF5236.jpg[/IMG]
04 Intimidator Feb 14, 2008 09:30 AM
RE: FOG LIGHTS
As long as the LT has the wiring harness you can just plug them in and change the switch on the inside.
If not, aftermarket will be the easiest way to go. OEM is a PITA to install.
RickCoMatic Feb 14, 2008 12:34 PM
RE: FOG LIGHTS
My 04 LS didn't come through with Fog Lights. I thought that the "Louvers" in the spaces for the Fog Lights looked awful; so I started a campaign to find Fog Lights that would fit.
After looking at a couple of hack-jobs that some guys did to mount aftermarket Fog Lights; I was convinced that OEM was the way to go. I searched "car.parts.com" and got a Boneyard to sell me stock Fogs at a very reasonable price. They MOUNTED easily enough because the behind-the-bumper locating tabs were in place. What was NOT in place were the Pigtails and Plug-in's for the Fog Lights.
IF you have a Monte pre-wired for Fog Lights you'll just have to mount them and they'll work. If not, you can't adapt the wiring because the Body Control Module would need to be programmed.
I'm going OFF the wiring harness and wiring-up my own OFF BCM - switched and relayed wiring to get the Fog Lights to come on. The hardest part is getting the Plug-in's for the OEM Fog Lights and finding a path through the Firewall for the wiring to the Remote Switch placement.
I have a handle on what I need to do, have the stuff and all the fittings ... just waiting for a break on the weather to do the wiring and keep the power to the Fog Lights OFF the Body Control Module.
04 Intimidator Feb 14, 2008 02:37 PM
RE: FOG LIGHTS
ORIGINAL: RickCoMatic
Thats what I had with my old Saturn. Like I said PITA.
But its great when done!!!:)
rj Feb 14, 2008 04:37 PM
RE: FOG LIGHTS
Also to answer your question, yes the lights will go right in the front facia.
