7th Gen ('06-'07): Engine smell?
Old Nov 26, 2021 | 06:38 AM
CASCO's Avatar
Default Engine smell?
I can’t find any leaks anywhere- but when I park the car the garage I smell what smells like a hot fluid leak on the exhaust manifolds - it’s strong and very concerning and annoying. So does the LS4 have a leaking intake manifold history like on the LS engines? BTW I always keep a eye on all fluid levels.
Old Nov 27, 2021 | 09:24 AM
JTBell's Avatar
Any engine codes, are the gauges all in normal ranges, all dipsticks and fluid fill caps clean seated w/good gaskets. I would guess loose rad cap or just bad cap letting a little pressure out.
You find anything since yesterday?
Old Nov 28, 2021 | 06:04 PM
CASCO's Avatar
All is good
Old Nov 28, 2021 | 08:37 PM
My water pump went out on my LS4 very early in life (maybe 25k miles?), but I'd think you'd see that/ have drips on the ground when running.
I don't think I've ever heard of a common coolant leak point (like the upper intake on the NA 3800s). Is anything wet / damp when looking from the bottom? Or is it bone dry under there?
Old Nov 29, 2021 | 01:35 PM
CASCO's Avatar
All is good - no signs of anything dripping or seepage or stains on floor. I’m completely stomped, but it is so hard to see all around the entire engine as you know.
Old Nov 29, 2021 | 02:35 PM
It is for sure. I wonder if the autozone rental manual pressure tester has an adapter for the oddball LS4 'overflow cap'? Would be nice to pressurize the system with the engine off to see if you can see / hear anything with everything else quiet (and see if it holds pressure or not).
Old Nov 29, 2021 | 05:11 PM
CASCO's Avatar
Antifreeze dripping on the exhaust manifold has a sweet smell to it - this smell is very harsh and burns your nose.
az2020
Aug 22, 2019 04:14 PM
Father Torque
Oct 20, 2015 01:34 PM
TheOther85
Mar 19, 2014 02:48 PM
bigmichaelcool
Dec 30, 2011 03:56 PM
Jack The Ripper
Mar 31, 2010 01:46 AM
