Dash Pulling Up?
1 Attachment(s)
Hey everyone. I hope all is well with you guys. Quick question...is anyone's top dash pad pulling up in the middle or sides? I have seen several 6th gens on car lots and the middle of the top dash pad above the radio is pulling up bad. I just noticed on my 2002 that the corners of the top pad near the doors are just barely starting to pull up. Mine still looks near perfect but if this ever happens what do I do? I attached a picture of a car I found online with the issue. Thanks!
I've had older camaro's that used to do that, and you could buy a replacement dash to put over, but I never did.
I believe they are held down with a strong glue that kind of stays sticky, that is what we used to use at the plastics factory I used to work at, so you may be able to find a strong interior automotive glue that will hold the dash down. Wish I could be of more help but I haven't seen a dash do that in quite a few years |
This has happened to quite a few of us here including mine.
