Brake Problems
Old Nov 5, 2012 | 02:48 PM
Lorenzo's Avatar
Default Brake Problems
Ok so on Friday i replaced all 4 calipers because 2 of the 4 were seizing so i said might aswell do them all before the other 2 sieze. So everything was good placed the 4 new ones on and began to bleed them. Everything went well pedal was firm when i was backing up. As soon as i start to go over 20 kmh and try to stop the pedal just goes straight to the floor before it stops. So figured okay air in lines we can bleed them again. So we bled them again today and made sure to get all the air out. It feels better now but still the pedal is terrible! Like when i push it down a touch i can feel the car stopping but then it goes away and the pedal just sinks till it starts to stop again. Its full on fluid, we never let the master cylinder go dry, we started from lr,rr,lf,rf and still i have a ****ty pedal. We were thinking of bleeding the master cylinder but we couldnt find the bleeder valve. Any thoughts guys?
Old Nov 5, 2012 | 03:00 PM
nitehawkjcb's Avatar
The master cylinder may be failing man that's the last thing I can think of unless you have a blockage in the lines
Old Nov 5, 2012 | 03:09 PM
One of the lines might also have a very slight puncture to it, allowing air to get in
Old Nov 5, 2012 | 04:11 PM
Lorenzo's Avatar
Well it cant be the MC, it was working perfectly before i changed the calipers, and if a line was punctured then fluid would be spilling right? The Fluid level hasnt changed in the MC so i know its not leaking anywhere.
Old Jan 26, 2013 | 04:02 AM
Chevelle's Avatar
Take and push brake fluid through bleeder on calipers up to master cyl r/rear l/rear p/front and dr front this should push all air out through the master cyl leave top off when u do,always worked for me,even on the most stubborn air pockets.
Old Jan 27, 2013 | 08:17 AM
Lorenzo's Avatar
Fixed this problem a long time ago haha ! My Friend who did the back 2 calipers put them on backwards, therefore there was always air in the system. Flipped them around and re bled them and everything was back to new!
Old Jan 27, 2013 | 08:34 AM
So its all good now Eh?
Old Jan 27, 2013 | 11:03 AM
Lorenzo's Avatar
Yep! Everything is working as it should! Ive replaced alot since then
Old Jan 27, 2013 | 05:25 PM
Kewl, Glad you got it repaired!
Jerry Barao
Jan 12, 2013 07:54 AM
ladybridgeport
Feb 1, 2012 10:46 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
