400 Turbo-Jet / Turbo-Fire question
Old Jul 19, 2012 | 08:23 AM
taz7nads's Avatar
Default 400 Turbo-Jet / Turbo-Fire question
in 1970, what was the difference between the 400 Turbo-Jet vs. Turbo-Fire? I know the Turbo-Fire was 265 hp, while the Turbo-Jet was actually a 402 cid big block with 330 hp, but don't know anything more than that.
Old Jul 19, 2012 | 09:01 AM
Turbo Jet 400 was a sort of enlarged version of the 396 big block V8, the Turbo Fire 400 was a small block V8 which was more similar to the 350.
Old Jul 19, 2012 | 10:09 AM
I found this. Monte Carlo: 1st gen 400 engine option clarification
this is from the article:
In 1970, if you ordered the SBC "400" (option code LF6), you received a
"265 hp Turbo-Fire 400 V-8 engine (regular fuel)". If you ordered the
BB 402 (option code LS3, and known as a "396" in any Chevy SS except for
the Montes), you received a "330 hp Turbo-Jet 400 V-8 engine".
Old Jul 19, 2012 | 10:20 AM
TheMonteMan's Avatar
bingo^^^ 400 is the small block. 402 is the bored out 396 big block. the big blocks are physically larger, and have a canted valve setup. the stroke of the 400 and the 402 are very similar this gives the 400 big block like torque. its also the reason why the 400s crank is used in 350s to stroke them to 383. i personally have a 400 small block and can tell you they make a ton of torque, dont generally like to rev (they dont need to to make power), and are known for running hot. i wouldnt pick the 402 over the 400 unless the car i was going to put it in came with a big block. bbc parts are expensive, theyre heavy, and they dont just slide into a gbody.
Old Jul 19, 2012 | 12:28 PM
taz7nads's Avatar
thanks guys, that tells me exactly what I need to know. If a small block 400 was replaced with a big block, would the springs need to be changed for the additional weight?
BeachBumMike
Mar 24, 2015 07:52 AM
vikesfan
Jan 29, 2014 12:23 PM
00BlueMonte
Mar 10, 2008 10:25 AM
slips96
May 25, 2007 05:46 AM
RIVER RAT
Apr 20, 2006 12:38 AM
