2006 Monte Carlo Tow a Bass Boat
`Jeff`P, you did not post how big of a Boat ?
I'd find a friend with a truck : ) 4-Sure
2000-2007 Chevy Monte Carlo - Class 2 "No Drill" Trailer Hitch
August 20, 2009
Average Delivery Time: 4 to 10 Business Days
Description
Tow up to 3,500 lbs with this Curt Manufacturing Class 2 Chevy / GMC Monte Carlo trailer hitch. Custom made to fit the Chevy / GMC Monte Carlo this hitch a has 1 1/4 inch square receiver-style opening to accept various ball mount heights. This trailer hitch includes all required hardware, a standard height ball mount and hitch pin. All hitches are powder coated to resist rust and corrosion.
Note: The included ball mount accepts a hitch ball with a 3/4" diameter shank. The required hitch pin size (hitch pin is included) is 1/2" diameter. FEATURES
Weight Carrying Capacity 3,500 lbs. Max Tongue Weight: 350 lbs Class of hitch 2 Type of Finish: Black Powder Coat Hitch Receiver Opening Size: 1 1/4" Square Install Time: 40 minutes
Fits following years:
2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007
Fits following models:
View all "Trailer Hitches & Accessories"
Related Products:
2" Hitch Ball (Chrome) with 3/4" shank by Master Lock
SKU #: 2853DAT MFG: Master Lock Weight: 4
Our Price$6.95
Hitch Receiver Lock 1/2" & 5/8" Sleeved "Bent Pin" - by Master Lock
SKU #: 1377DAT MFG: Master Lock Weight: 3
Our Price$15.95
Part #: CT12028
Our Price: $196.95 $181.19 Price valid on orders placed through:August 20, 2009
- Custom fit for the Chevy / GMC Monte Carlo
- No Drilling Required
- 3,500 lb load capacity
- Powder Coated
- Includes ball mount, pin and hardware
- Limited Lifetime Warranty
- 1 1/4 Inch Square receiver opening
Our Price$6.95
Our Price$15.95
u could do it i just sugest not doing it alot will be rather hard on the clutches in the trany...if a manual it wouldnt be so bad...but did they even make a manual?...
great info on the trailer hitch space. keep in mind that 3500lbs is what the hitch is rated for, not the car itself. how big is the boat? do you know how much it weighs? how much tounge weight is there? since there isn't leaf springs like on a pickup, it won't hold much tounge weight at all. i would bet the monte would only take ~300lbs tounge weight max.
i've thrown around the idea of getting a trailer hitch to pull a single snowmobile trailer, but that's a lot lighter than a boat. if you can find all the weight and towing capacities (google that sh*t!) for your monte and then the weight of the boat, then you will have your answer.
I believe the owners manual says...1,000LBS max tow...Personally I would not tow anything more than maybe a jet ski with my Monte. But being its just around the corner you probably could get away with it.
I just think about having to pull the boat out of the water, and up the ramp...stress on the tranny for sure.
Then again, my dad used to tow a 17foot boat with his 1986 Camaro Z28 5speed. He said he just let the clutch out, and peels rubber all the way up the ramp in 1st gear.
