2006/2007 Monte Carlo Foglights, using H9 bulbs instead?
Old Oct 18, 2006 | 11:18 AM
06BlackSS's Avatar
Default 2006/2007 Monte Carlo Foglights, using H9 bulbs instead?
Just wondering if anyone has replaced the stock fog light bulbs H11 55W WITH the High Beam H9 65W bulbs? I would imagine it would be quite the improvement?
I had the headlights out last night and it is the same connector for both H11's and H9's
Regards,
Jason
Old Oct 18, 2006 | 04:52 PM
2006MonteCarlo's Avatar
Default RE: 2006/2007 Monte Carlo Foglights, using H9 bulbs instead?
i would imagine it would be brigther if the head light lines are limited to 55 w you might blow a fuse, anyway just to test them pull your hb out and put them in your fog lights and see if you see a difference, and that way you dont have to waste money on some bulbs just yet
Old Oct 19, 2006 | 03:46 PM
06MonteSS's Avatar
The highbeams are 65W, while the fogs are only 55W.
Just get some brighter bulbs... here's the bulb list from sylvania silverstars:
2006 CHEVROLET Monte Carlo
Low beam headlamp
H11-55W
High beam headlamp
H9-65W
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057LL
Tail light
3057LL
Stop light
3057LL
High mount stop light
Assembly
Fog/Driving light
H11-55W
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
578
Dome light
578
Step/Courtesy light
194
Trunk/Cargo area
912
Old Oct 19, 2006 | 03:56 PM
06BlackSS's Avatar
Thats the same site I got my information from as well. I am goign to try putting the 65W H9's as the fog lights, should be fine.
Jason
Old Oct 19, 2006 | 05:02 PM
do you guys have a trunk light??????
Old Oct 19, 2006 | 05:09 PM
06MonteSS's Avatar
ORIGINAL: 2006MonteCarlo
yup... you don't?? there should be a small white plug dead-center at the top of your trunk when you open the trunk lid...
open your trunk - and in the middle, right below the black rubber seal, there should be a little light up under there... white plug going up to it. Maybe the plug is knocked out or not in all the way... it's easy to hit putting stuff into the trunk - I've done it before...
Old Oct 19, 2006 | 08:28 PM
Yellow_Monte's Avatar
Speaking of lights
Has anyone tried the new Sylvania Silverstar Ultras?? They are supposed to be 20% brighter than regular silverstars.
Old Oct 21, 2006 | 09:29 PM
k thanks i am going to go check, i was really really impressed with the normal silverstars the ultras will be well worth the money
btw do you have a hood light to?
Old Oct 22, 2006 | 12:36 AM
Bigg J's Avatar
Mine doesn't (2005 LT).
