Tail Light Mod
5 Attachment(s)
Ive had a few ppl lately ask how I done this so figured id do a quick write up :thumbsup:
Basicly this mod will make your tails look like this when lights are on Attachment 33688 Top is still the signal and bottom the brake I first went to Car Quest and got a 3 wire GM socket about $12 each or you can goto a junk yard and pick up another set of tail light harnesses Attachment 33689 First you need to cut one tab off the socket so it fits in the tail light like this Attachment 33690 Next step you cut the 2 wire socket off your harness (no pic sence i done this 2 years ago) Than you wire the 3 wire socket up to the harness, black is ground and depending on which socket you buy the major wire goes to the green wire (if u buy a new socket the colors are the same) Attachment 33691 Next step cut the black and white wire on the lil side socket and leave plenty of wire on each end, than wire the minor wire from the 3 wire socket to this Attachment 33692 Hope this helps anyone who wants to do this :thumbsup: |
Nice Write up.:thumbsup:
:thumbsup: very nice Mike!
Thanks for the post. |
Much appreciated, thanks man!!
Tail Light Mod
Hey, thanks for the information on the tail light mod - need some clarification - were you able to use the same bulbs? Also, I'm a little fuzzy on some of the steps...your help will be much appreciated... thanks!
I believe the bulbs are different, look at the part numbers on the bulbs to be sure, otherwise you will have to buy another brake light bulb nothing major.
Originally Posted by Jerry Allonas
(Post 719685)
tail lights
I have a 2000 Monte Carlo I put 2006 Monte Carlo tail lights on it all the lights works turn signal,hazard work except the brakes when I push the pedal down it does do anything no brake light
Originally Posted by Abe0987
(Post 731086)
