Rear Defroster Fix (Circuit Breaker)
5 Attachment(s)
First, I want to thank BBEngineer and Duke0466 who shared info on a thread I started a while ago:
https://montecarloforum.com/forum/ge...r-24836/page4/ Second, despite being a GM fan boy, I will say, this was RIDICULOUS! GM tells you there is a circuit breaker for the rear defroster but I have never found documentation that says WHERE it is (again, thanks Duke). Third, the pics are from my wife's '05 Impala. I will be doing the same to my Monte when I uncover it in spring. Knowing what Duke shared and who identical the '00-05 Monte and '00-'05 Impala are, I'm sure you'll find this info spot on. Symptoms Rear defroster does not work at all OR it works for perhaps 1 second. Fix Before you start, rule out the basics. Sadly, the '00-'05 W-Bodies have a history of the window tabs falling off (solder joints break). A quick visual inspection can validate those are good (there are steps on the Internet discussing this in more detail). Make sure the relay for the defroster is good. If those two check out, carry on. I am going to explain how to inspect the circuit breaker (that is documented on the label for the passenger side fuse panel, but GM did not clearly explain those breakers are on the BACK of the fuse block). Step 1 DISCONNECT THE BATTERY! You will be removing the fuse block, disconnect the battery to prevent any mis-haps in this process. Remove the passenger side fuse panel. Also remove the passenger side hush panel (it's just two tabs you push with your thumb and it drops down). In my case, GM had another item holding the panel in (and I did not want to remove it, as I did not have the right tool). But, you just need to drop the hush panel to get access to the bolts/screws holding the glove box door on. There is 5-6 of them. Remove them and then remove the glove box door. https://montecarloforum.com/forum/at...1&d=1326043584 Step 2 Loosen the bolt inside the gray box on the fuse block. This bolt does NOT come out. This is the bolt used to hold 1 of 2 wiring harnesses to the fuse block. Once it's loosened all the way, pull this harness off (it may take some gentle prying with a flat head screw driver). Also, I took the gray cover off, but it's not needed to do this job (as I learned after the fact). You will also see a wire with yellow connectors hanging in this pic. I believe this is to the air bag. It is clamped to the side of the fuse block. Gently slide it off the fuse block and then move it out of the way. https://montecarloforum.com/forum/at...1&d=1326043584 Step 3 I gave two pics of this step. You will loosen another bolt in a black box for a wiring harness like you did in step #2. You will also remove the only bolt holding the fuse block in. Once you have those two released, there is a single tab you need to press in on and pivot the fuse block out at and angle (as doing so, try to release the wiring harness on the back side of the block, again, some gentle prying with a flat head screw driver may help). I also found removing the relays from the front of the fuse block helped. NOTE: You can see a circuit breaker on the back in my pics. Sadly, this is NOT the rear defroster breaker (I believe it's for the power seats). https://montecarloforum.com/forum/at...1&d=1326043584 https://montecarloforum.com/forum/at...1&d=1326043584 Step 4 This pic is showing the fuse panel is now OUT of the car. You are seeing the large wiring harness hanging there. https://montecarloforum.com/forum/at...1&d=1326043584 |
1 Attachment(s)
Step 5
Now that you have the fuse block out, you will see BOTH circuit breakers (which were hidden on the back side). The arrow is pointing to to rear defroster breaker. In this pic, I already replaced it (the original one was not green as seen here). When I removed the breaker, I could tell right away is was bad (if you shook it, it rattled). To be sure use a volt meter on it and do a simple continuity test. I could NOT find a direct replacement at the parts store. The blades on it were wider then the what would fit into the block. I had to use the Dremel to grind them down to fit. Update: Check your parts store for the following fuse (my stores could not match the original one, but the part number might help more):
Originally Posted by limemonte
(Post 595666)
30a breaker is part #MNB30
Once you have replaced the circuit breaker (or determined it was not bad), simply repeat the steps to put the car back together again. Again, I know these steps are for a '05 Impala, but I am sure you will find them to be the same for the '00-'05 Monte. I will be going through this in the spring on my Monte. :thumbsup: |
Nice write up thanks..:thumbsup:
Great write up
Thanks guys. Hopefully this info will help a lot of other people who were equally as confused as I as to where the circuit break was...
Nice write up Maniac! Now only if I can find a write up on "how to fix a broken defrost connector on the rear window (inside)". Then I will be all good!!!!
Originally Posted by rgant_19
(Post 522662)
Thanks for the reply chi! In chicago I went to o'reilly's and autozone which they said it was not sold since august of last year. So I guess I will try napa, which I am pretty sure advanced auto parts will say the samething...
(Post 401342)
https://montecarloforum.com/forum/ge...r-24836/page4/ Second, despite being a GM fan boy, I will say, this was RIDICULOUS! GM tells you there is a circuit breaker for the rear defroster but I have never found documentation that says WHERE it is (again, thanks Duke). Third, the pics are from my wife's '05 Impala. I will be doing the same to my Monte when I uncover it in spring. Knowing what Duke shared and who identical the '00-05 Monte and '00-'05 Impala are, I'm sure you'll find this info spot on. Symptoms Rear defroster does not work at all OR it works for perhaps 1 second. Fix Before you start, rule out the basics. Sadly, the '00-'05 W-Bodies have a history of the window tabs falling off (solder joints break). A quick visual inspection can validate those are good (there are steps on the Internet discussing this in more detail). Make sure the relay for the defroster is good. If those two check out, carry on. I am going to explain how to inspect the circuit breaker (that is documented on the label for the passenger side fuse panel, but GM did not clearly explain those breakers are on the BACK of the fuse block). [quote]Step 1 DISCONNECT THE BATTERY! You will be removing the fuse block, disconnect the battery to prevent any mis-haps in this process. Remove the passenger side fuse panel. Also remove the passenger side hush panel (it's just two tabs you push with your thumb and it drops down). In my case, GM had another item holding the panel in (and I did not want to remove it, as I did not have the right tool). But, you just need to drop the hush panel to get access to the bolts/screws holding the glove box door on. There is 5-6 of them. Remove them and then remove the glove box door. https://montecarloforum.com/forum/at...1&d=1326043584 If there is a problem with the circuit breaker then you'll probably need to use a tester on it first to confirm. If it's no good you'll need to replace it. [quote]Step 2 Loosen the bolt inside the gray box on the fuse block. This bolt does NOT come out. This is the bolt used to hold 1 of 2 wiring harnesses to the fuse block. Once it's loosened all the way, pull this harness off (it may take some gentle prying with a flat head screw driver). Also, I took the gray cover off, but it's not needed to do this job (as I learned after the fact). You will also see a wire with yellow connectors hanging in this pic. I believe this is to the air bag. It is clamped to the side of the fuse block. Gently slide it off the fuse block and then move it out of the way. https://montecarloforum.com/forum/at...1&d=1326043584 [quote] I got the same carpet setup in mine as well hah. Step 3 I gave two pics of this step. You will loosen another bolt in a black box for a wiring harness like you did in step #2. You will also remove the only bolt holding the fuse block in. Once you have those two released, there is a single tab you need to press in on and pivot the fuse block out at and angle (as doing so, try to release the wiring harness on the back side of the block, again, some gentle prying with a flat head screw driver may help). I also found removing the relays from the front of the fuse block helped. NOTE: You can see a circuit breaker on the back in my pics. Sadly, this is NOT the rear defroster breaker (I believe it's for the power seats). https://montecarloforum.com/forum/at...1&d=1326043584 https://montecarloforum.com/forum/at...1&d=1326043584 Step 4 This pic is showing the fuse panel is now OUT of the car. You are seeing the large wiring harness hanging there. https://montecarloforum.com/forum/at...1&d=1326043584 |
No prob CarDude8! This was a means to a long time problem. I was thrilled to share this write up. Glad it's helping others :)
| All times are GMT -5. The time now is 02:45 AM. |
