Making a CAI box
the way that i made my box was i used some 1/8 inch thick plexy glass from menards.
1.I first made the back heat shield that would be closer to the engine and built everything off that. I would cut every thing using a razor blade by scoring both sides of the plexy glass and then just apply pressure to make it snap. (make sure you score it about 5 or 6 times with a good amount of pressure. 2. I used a hole saw for the intake tube to be able to slide into but i made it a little smaller so i could sand it out and make it fit snug around the tube. 3. then i built the bottom of the heat shield to make the back and tried to make it bump next to my p.c.m. 4. i then made the side wall for it that would be next to the radiator hose 5. i then connected the side to the back and then the back to the bottom and then the side to the bottom using small L brackets with rivets. 6. In order to get the box/ heat shield in i had to take off my cross brace to fit it in. 7. Then i got another L bracket and attached it to the side heat shield and to the cross brace to hold it all in place. I was then done and this all took me about 2.5 hours. One problem that i did encounter though is making the hole for the intake tube the plexy glass has a tendency to crack so you should take your time while doing this. Items: Plexy glass 1/8 inch think by 24*24 inch razor blade hole saw drill file rivets and rivet gun L brakets wrench for cross brace tape messure straight edge to help with cuts http://www.cardomain.com/ride/2571140/5 |
RE: Making a CAI box
:eek:Luke :eek: Thanks for the super `pic's and write `up Now, tell you dad you need more money for `gold, LOL, I mean `Gas : ) I know the first time I had a CAI on my car, I just couldn't stop kick'in it down to hear the awesome sounds. Some of my `friends thought I put a supercharger or turbo on my ride : ) EnJoy, be safe & have `fun on your B-Day : ) `Space & the Beach `Bum's |
Nice project!
How much did you save with your DIY project? |
A suggestion for anyone trying to do this yourself, forget the Plexiglas (acrylic) and instead use Lexan or similar (polycarbonate). Costs about twice as much, but it's not brittle like the plexi', and just as easy to work with, and maybe easier because it won't crack.
Try a glass shop for it, and you can probably go to 1/8" instead of the 1/4". It's THAT much stronger. |
ORIGINAL: RocknSS04 Try a glass shop for it, and you can probably go to 1/8" instead of the 1/4". It's THAT much stronger. also i just realized that in my original post i said 1/4" but used 1/8" then i probably saved around $80 doing it my self |
You saved $80, but you got one probably WAY better than you could buy, or that's at least my opinion of my K&N.
I made a topic about this not too long ago. I am planning to build my own (not willing to pay $300 for the K&N FIPK) plus I intend to actually improve on their design by making the entire thing a sealed, insulatedsheet metal box with a lexan top so you can see the K&N filter inside. It's pretty much supposed like a WizAired CAI. Here's a link to the thread where I provided more specific design ideas.
https://montecarloforum.com/m_76015/tm.htm I don't have an aftermarket intake on yet, but I love the suction sound that they make. So if I make a fully sealed cold air box for it then would I be able to hear that suction sound less? |
Looks a lot better than I expected!! Great job!
