ls4 engine mount, throttle body spacer.
engine mount flip:
1: romove the dog bone by un bolting it from the engine and mount on core support. they are 15mm. 2: reinsert bolt into mount on core support. tighten it hard. rock it back and forth whil spraing wd40 inbetween it and metal bracket. 3: using 2 15mm whrenches put both on each end. turn them both at the same time towrd the engine. 4: if its not moving you did not lube it up enough. 5: once the rubber mount has the solid end of it towards the engine re insert dog bone. throttle body spacer: 1 remove air intake tube. if its k&n just loosen all the clamps and disassemble it. 2 loosen the 4 10mm bolts holding the throttle body on. 3 set back the throttle body and insert gasket into spacer(provided) 4 using the supplied 10mm bolts insert one through the throttle body and spacer. start the threads. 5 there is a plug going towards the fire wall that will be in the way. they well move. 6 insert the remaining 3 bolts tighten one corner. then the opposite corner. then repeat. 7 reinstall intake. and enjoi |
What do these mods accomplish, exactly? Rather, why would i do them?
Mount flips are common because the stock mount the way it is aligned allows for more engine movement (so you feel less vibrations, but can lose a HP or 2 in the movement) when you flip it, you make the harder sides take the place of the softer sides so that the engine moves a little less, freeing up that HP.
TB Spacers are just a waste of money. Supposed to add more room for air, but not worth it. |
(Post 206242)
http://www.ls1tech.com/forums/ls4-fr...le+body+spacer |
Oh yeah?
So they work for you LS4 guys? That's great to hear :) |
(Post 206247)
Oh yeah?
What is a good TBS for the LS4 motor?
Read the link that Rick posted
Totally missed that. THanks.
i know this is an old thread...but i put an Airaid TBS on my car tonight took a video of the whistle noise it makes(not the best video but will kinda give you the idea) for those 7th gen owners that have been wanting one
YouTube - ‪2007 monte carlo ss throttle body spacer install‬‏ |
