blower motor
Only blows on #5 on high any ideas? anybody have this problem? Blower motor maybe Thanks
probably the blower motor resistor or the blower switch.
check out the resistor first. |
(Post 557822)
GREAT info thread here for members, especially for alot of the new members who seem to keep making posts/threads about the same problems :)
Thanks Chibi
Recently copped a 2005 SS supercharged and the wipers stick in every position except the top two highest levels. Then I keep getting Traction service requested and my battery light comes on for at least 5 sec.'s when started ( I donno if that's normal). According to my system, I can't use the traction. But tomorrow I will look into your suggestions and hope for the best!
what if my wipers don't work at all, but i can hear the motor working? there's a little white tab thing under the cowl that keeps popping off...what is that part called/is it part of something else? please help! had to drive 45 mins home in pouring rain without wipers tonight!
Thanks for the info Chibi !!!! :thumbsup:
Heat not blowing
I have a 2002 Monte Carlo and my heat is not blowing Ive checked all the fuses that I could think of but i have had no success could someone help me maybe im checking the wrong fuse or maybe its something else that Im not looking at. Please help chicago winters are no fun without heat!!!
hey
I have the same car. Mine did the same thing. Ended up being a short in the pcm fuse box wiring. Do you have spark?
Originally Posted by drmusicmaster
(Post 540907)
My vehicle has been running fine over the last 3 weeks i've owned it, but today when I went to start the car, it would not start. It turns over, the fuel pump runs, there is no issue with battery. I checked all of the fuses, all good. I'm not sure where to go from there.
It's a 1997 Monte Carlo LS. |
electrical problems
out of nowhere my 03 monte carlo's traction control turned off and says to service it. On top of that my brake light and abs light stays on. After a few days they all turned off by itself only for it to come back 2 days later. Now my heat also stopped working and i notice my temp is running high.
