How to remove your center console
6 Attachment(s)
I had to take my center console out to plan for my handbrake installation (will do a how-to on that when I finish as well), and didn't see a how-to guide on how to remove the console!
It's not so bad. Things you'll need: 5/16 ratchet bit gator grip w/ vertical extension drill About 20 minutes
I don't know how common of a thing this is for people to do, but just in case someone else wants to do it, here you go. :thumbsup: |
good write up!!
unused connector
Hi, have a question for you. When you had your console apart did you notice a harness connector wrapped in a piece of foam below the traction control connecter. If so, do you know what it's for? It's not in use in my car (05)
Thanks |
Originally Posted by ssdriver
(Post 566082)
Thanks |
glad i found this, i spilled tea down in my center console and now the car sometimes doesnt know when its in park, prohibiting me from getting my key out :/ this will come in handy when i clean it out
Good step by step instruction! My question for you is..In that last picture there I see the 2 small 5 pin harnesses, One is black one is white, both are identical..I just rewired mine and I am currently stuck at finding where these 2 "female" harnesses plug in? Any help would be appreciated..Possibly a closeup or anything would help at this point. Thanks again.
Thanks, Great write up.
