Originally Posted by Ed_n_Lucys_2002SS
(Post 493958)
I've seen posted here that in order to "trick" the DRL's, you pop off the top dashboard to gain acces to the sensor to cover it with tape. Is it easy to re-install the top cover once it's been popped off? I've never messed with these interior bits before and I'm kinda nervous about popping stuff off.
(Post 493958)
I was told that HID's burn up factory wiring. Is this true? If not, could someone tell me how to install Fogs, Highs, and Lows with the relay kit into my 2000 SS? I will have 2 12" Jl Audio subs with a 500 watt Alpine amp. I don't want the lights to dim when I'm using my subs either. Is this possible?
(Post 493997)
Just curious, why do you want to "trick" the drls?:confused:
So the DRLs dont come on during the day... what good does HID lighting do when the sun is out?
Originally Posted by 75JMO93
(Post 501935)
Or some amps have capacitors built in (like mine) |
what kit is right for our car if we were to buy off ebay?
This is not hid related, but has anyone else had their monte not start when the gas cap is off?
(Post 501935)
Replacing the bulbs that also double as the DRL is not recommended. Since they run at half power when in DRL mode there won't be enough amperage to excite the ballast. Here are a couple different installation guides: HID Installation Instructions - Xenon Install Instructions |
Originally Posted by Cynthia5368
(Post 599332)
| All times are GMT -5. The time now is 02:49 AM. |
