FWD Monte Maintenance at 100,000 miles
This applies to ANY FWD Monte hitting 100,000 miles (as they are all built of products that last a similar life span).
So you just bought a Monte with about 100,000 miles on it, give or take or you have owned it for a long time and are approaching the big 100,000 mile marker. With that, you want to keep things running smooth, then this reading is FOR YOU! Here are things that COULD help you avoid up coming issues by doing a little maintenance ahead of a potential break down. 100,000 Mile Maintenance:
Note: If you DON'T know the vehicle's history, then it is heavily recommended you do these.
Also a good note, not all of these items are strictly mileage based. For example, spark plugs can be rated 100k miles, but should also be checked after 5-6 years.
I would recommend ANYONE buying a 2000-2007 Monte to definitely look over every item on this list, even if they aren't near 100,000 miles. Because even if you bought the last ever made Monte in 2007, it is still over 6 years old. |
Great Information Jason and Mike!:thumbsup:
I have done most all of those things on mine! Since mines a 3800!:) Still runs like a fine swiss watch!!!:D I use non synthetic oil...But mine gets an oil change every 3 months or 3000 miles Faithfully. Which I have done since purchasing it brand new from the factory. However, since hitting 100,000 miles at every oil change I do ad some LUCAS HIGH MILEAGE motor treatment for added longevity and protection for my motor. |
All excellent maint reminders. Thanks for posting Jason.
As a diehard synthetic oil user, I can offer some change intervals recommendations for synthetic users: I run Mobil 1 full synthetic oil and change it every 7,500-8,500 miles typically...I've gone as long as 11,000 miles in between changes once or twice. Note, I only use Mobil 1 or Fram Xtra Guard filters (the gold one). My Monte has 198K and still runs strong as new following these change intervals. I drive mainly highway miles. For those of you more city based, I would recommend 7,000-7,500 mile intervals. Important to note and check is your oil level!!! Going 7,500 miles and beyond in between changes might require the occasional top off. |
Thanks everyone. I hope everyone finds this very helpful.
For years, 100,000 miles was the "kiss of death" on a car. But, for a long time now, the quality of the parts have increased, they run far better then they did in the past, 100,000 miles can mean it was just broken in. I know when I bought a '94 Grand Am with a 3100 v6 my friends thought I was crazy to think I could get it to 200,000 miles with a car that had about 80,000 something already on it. I sold it with a perfectly running drive train and 214,000 miles on it. The key is maintenance! I know some of our members own higher mileage Montes and want to make sure they serve them well for many miles to come. Another thing to keep in mind for those looking to buy a used car, get a sense if the people who owned it took care of it's regular maintenance. If it seems like they neglected oil changes (your most basic task to keep an engine going), you may want to step away. The last thing anyone wants to do is buy a car and end up paying for the sins of the last owner.
(Post 584269)
Originally Posted by STUMPMI
(Post 584282)
Originally Posted by MAMONTE
(Post 584285)
(Post 584298)
Thanks for chiming in. I know you have shared your experience with synthetic oil and last I knew your Monte has a TON of miles on it and still runs great! Obviously your practice has proven to work well.
176,500 mi she has that pesky rear main seal leak and needs new rear struts. All i can i say is my uncle is pissed he gave it to me because he thought it had way less life left than it does. so long as it doesn't rust bad it will eventually get repairs done to engine tranny IF NEEDED. Still does a 9.3 sec 0-60
Thanks Maniac!! I used the "turkey baster" this past week end and did my brake fluid and power steering fluid! I must say F-ckin Brilliant!! got the baster at walmart for .88 cents!! worked like a charm brotha!! I had to tell the cashier how much it was and the guy in line behind me says, " kinda odd time to buy that" then I told him what I was doing with it and he says!!... "that's F-ckin brilliant!! lol!!! told him I learned it on my Monte porn site and we both chuckled...good times!!! thanks again!!
Any brilliant ideas on tracking down oil leaks? got my oil changed and the dude said I had multiple oil leaks but didn't say where? my 03 SS has 93 + miles on it and Im sure the valve covers are leaking and probably the pan gasket? is the rear main seal usually a culprit too?
great info!!
Very nice write up. my monte has 105k so I'm going thru the list. id like to get another 100k out of her.
one question.....should the brake rotors be replaced if replacing a wheel hub bearing assembly? as anyone had any luck with re tightening the oil pan bolts ? my pan is just seeping enough so you can see oil on the gasket. doesn't concern me at this pint really tho. only issue I have now is the dreaded ISS steering thump lol ill tackle that tonight tho. |
