Repair Guide: Finally!!! Gauge Cluster Problem Fix!! - Stepper Motor
Old Feb 22, 2009 | 08:04 PM
04 Intimidator's Avatar
Default Finally!!! Gauge Cluster Problem Fix!! - Stepper Motor
For those of you who own the 2000 - 2005 Monte Carlo we know that a popular problem has been our speedometer to stick, go dead, etc. I have FINALLY found the answer to the problem!!!
Inside the cluster there is a stepper motor for each gauge and they have a tendency to go bad. There is now an updated motor that is performs better.
Here is some information regarding the motor and associated problems. I have just copied/pasted in no particular order. I know I can fix these now so if someone would like me to, PM me and we will set it up.
If your Speedometer is experiencing any of the problems listed below, then these NEW UPDATED stepper motor will fix your problem. [ul][*]any gauge dead[*]stickey gauges[*]gauges not reading correctly[*]Needles peg out, and come back after it sets and then it only goes down 5 miles at a time when you turn the key on.[*]And any other weird thing.....
[/ul]THE BAD STEPPER MOTOR IN YOUR SPEEDOMETER IS PART # X C5 168
THE UPDATED STEPPER MOTOR WITH THE FIX IN THEM IS PART # X 25 168
UPDATE STEPPER MOTOR, PART # X 25 168 THAT GO BAD IN THE TRUCKS AND CARS LISTED BELOW,[*]FULL SIZE SIERRA[*]SILVERADO[*]SUBURBAN[*]TAHOE[*]YUKON[*]ESCALADE[*]AVALANCHE[*]DENALI[*]GMC ENVOY[*]TRAILBLAZER[*]H2 HUMMER[*]IMPALA[*]MONTE CARLO[*]ENVOY[*]CAVALIER[*]SUNFIRE[*]VENTURE[*]ASCENDER [*]SILHOULETTE
Old Feb 22, 2009 | 08:23 PM
ChevySSGirl's Avatar
Default RE: Finally!!! Gauge Cluster Problem Fix!!
good info! the speedo was wayyyy off when i test drove my car, they put a new one in for me though.
Old Feb 22, 2009 | 10:04 PM
I had the temperature guage go on mine last year. Dealer replaced under extended warranty.
Old Feb 23, 2009 | 11:52 AM
rj's Avatar
rj
Good info.
Any chance we can make this thread a sticky at the top?
Old Feb 25, 2009 | 04:38 AM
04MonteLS's Avatar
ORIGINAL: 04 Intimidator
So has anyone actually done this repair/upgrade? I need it desperately as all of my guages are stuck now but would like to know if it's something I should consider taking on myself or having it done at a shop.
Old Feb 25, 2009 | 05:01 PM
It's about a 30 minute job once the cluster is out. All you need are the motors and know how to solder decently.
It's a little complicated but you turn the dials back to zero, tape them in place, put a mark on the tape were they were located, pop one off with a fork. Then each motor has 4 solder points on it. You desolder them, put the new motor on and then put the dial back on. Repeat until they are replaced.
Old Feb 25, 2009 | 06:30 PM
ORIGINAL: rj
Good info.
Better yet. I'll sticky it in the DIY/How-to section.
Old Feb 25, 2009 | 07:56 PM
04MonteLS's Avatar
I happen to be quite handy with a soldering iron so this sounds like a task I could handle. Thanks for the rough guide there, gives me a good idea of what needs to be done. This would be the perfect time to install some custom guages faces. It would be nice to have a guide with pictures, any chance you could make that happen?
Old Feb 25, 2009 | 08:56 PM
ORIGINAL: 04MonteLS
Needy.
Here is a walk through that is from a Blazer, not quite the same, but close enough.
The cluster is constructed from 3 pieces which are held together with clips. Remove the front clear cover by unfastening the clips.
Turn each needle counter-clockwise until it stops as shown below and then mark off the location on the tape with a pen. If you do this, you should have no issues with calibration when you reassemble.
Once you have your positions marked, turn each needle counter-clockwise until it breaks free from the shaft. Then use a fork to pry each needle off. It will take a little force, but just be slow.
Unfasten the remaining clips that hold the back cluster cover in place and remove. You will then be able to pull the circuit board off.
Notice the 6 stepper motors, each about the size of a quarter.
(Replace stepper motor)
On the reverse side of the circuit board you will need to desolder the 4 points that are holding the motor on. These are easy to determine as they stick up a bit more.
Heat the solder and use a solder-sucker to remove the solder. If you don't have a solder-sucker, you can have an extra hand pry at the motor from the other side as you heat.
**Just be careful not to heat things up too much as this is a circuit board and you can harm other components if not careful.
I was replacing my speedometer motor, so I desoldered the following points.
Once the old motor is off, make sure the holes are clear of solder and put your new motor in.
Resolder your 4 points and place the circuit board on the back cover. Fasten the overlay piece back on now.
Now press each needle back on in the 12 o-clock position. Then turn each needle back to your mark on the tape. If you miss the mark just keep turning counter-clockwise until you come around again.
To test things out, plug the wiring harness back to the cluster. You should immediately see the needles jump down and then up to the original 'zero' points.
Make sure the needle for your new motor moved. You should really test this out first before reassembling everything to make sure your needles go back to their original points.
Typically, the gas gauge needle is a tick or so below empty. My RPM gauge was also about 100 rpm under zero at the rest position, so I made sure they were exactly in the same spot after I plugged the cluster back in.
Yours may differ slightly.
Once you determine your needles are correct, just snap the clear plastic cover back on the gauge.
(Reassemble)
Attach the cluster back to the dash and reassemble the dash in reverse order.
Old Feb 25, 2009 | 09:44 PM
04MonteLS's Avatar
ORIGINAL: 04MonteLS
Needy.
(Reassemble)
You rock! I'll be calling Chevy tomorrow to order the motors, I've been dealing with spastic guages for about a year now. Not really been a big deal but it is something I'd like to get fixed and now I can. Thanks again.
But before I do all that, I need to order some custom guage faces. Anyone make them for the LS?
