Change the HeadLight Bulbs
I used Sylvania Silver Star Bulbs : Purchased at WalMart $38 for a set (total cost $76)
High Beam 9005ST Low Beam 9006ST READ DIRECTIONS FULLY BEFORE YOU START NEVER TOUCH A HALOGEN BULB WITH YOUR HAND, THE BODY OIL CAN DAMAGE THE BULB, USE A PAPER TOWEL Step 1: Pop the hood Step 2: On the driver side, to far right and rear of the head lamp, there is a white plate that locks the headlamp into place, just pull it up. Step 3: The same plate is on the left of the headlamp. I could not get the black piece off that was covering the plate, so I used a long screw driver to pry it off. Step 4: Pull the headlight casing out Step 5: Pull off the weather proof cup from behind the low beam Step 6: Reach in a turn the light bulb (I believe counter clock wise) Step 7: Unlock the bulb from its wiring hardness, but lift up on the clasp Step 8: With a paper towel, pull the light bulb out of the socket Step 9: With a paper towel, put the new light bulb in and make sure it locks to the wiring harness. Step 10: Put the weatherproof cup back on Step 11: Replace high beams same way if needed Step 12: Put fixture back into place Step 13: Replace the white plates on the right and left sides to lock the fixture in Here is a tip, if you can not put the left side on due to some black pate that is in the way, get under the car and put the plate on upside down, just follow the radiator all the way up. Step 14: Test bulbs Step 15: repeat steps for passenger side. NOTE: This side is a little tight and the fixture will not come out as much as the driver side did, DO NOT PULL OUT MORE THEN ALLOWED |
RE: Change the HeadLight Bulbs
that sounds good, do you have any night pics of the bulbs once there in? i want to change mine to kinda of an HID look. but i'm not sure what to get
ORIGINAL: 96_z34 that sounds good, do you have any night pics of the bulbs once there in? i want to change mine to kinda of an HID look. but i'm not sure what to get |
ORIGINAL: montejass ORIGINAL: 96_z34 that sounds good, do you have any night pics of the bulbs once there in? i want to change mine to kinda of an HID look. but i'm not sure what to get |
Installed the silverstars... don't hesitate.
First drive and i love them. Tj |
ORIGINAL: budweiser2983 i purchased my bulbs from here...more than one set at that... i recommend! www.eurodezigns.com theres a couple pics on my site - http://www.cardomain.com/ride/2069058 |
ORIGINAL: budweiser2983 umm.... how bout no. if any of em suck it would be silverstars. they only last more than a year because they arent ne different than a regular halogen bulb...not to mention way over priced. and there is no "bad set." a true HID bulb does not last a year... so dont complain. jus stick to your sorry silverstar bull. im looked at luminetics...as they were 25 bucks as well. never tried em .... so take ur pick.................. Are you under the impression that Eurodezigns are HID bulbs? The Eurodezigns bulb IMO had a better blue look but were no where close to the intensity of SilveStars or Luminics. I have Luminics lows/fogs and Silverstar highs. I've had this set running for five months now, time will tell I guess... True HID bulbs are rated to last 2K-3K hours. |
Ya know man.. no need for the tude.
You don't like the silverstars.... fine. But don't get mouthy. I think Budweiser sucks!!!. How do they get the mules to pee in the cans & bottles?. Your allowed your opinion, but don't slam those that like something.. was your money spent to buy the silverstars for our cars? No.. it wasn't. This place is meant to be fun, and share info. 95 percent of the time i let this crap slide, but everyone has days were they don't. If you want to contribute and share info.. cool. If not, you might find moderators showing you the door. Tj |
im just going to lock the topic. Its getting a little outta hand. i will post the bulb replacement as a new topic, lock it, and keep it at the top of the DIY Forum so other members can be helped by it.
thats good stuff
