3900 idler pully replacement
17 Attachment(s)
This may vary on your vehicle as this was done on my 08 impala with the 3900, it should be the same or similar as your 06-07 monte carlo
I replaced the lower one, locally best price I found was $66 but Rockauto.com had AcDelco for $34 so I went that route, this could be used for any of the 3 idler pulleys I could probably get a cheaper one but if I can replace it with AcDelco I will Attachment 21573 Attachment 21574 Tools needed 3/8 ratchet 10mm wrench 13mm socket Piece of pipe (not necessary but helps) Step1 Pop the hood Attachment 21575 Attachment 21576 Attachment 21577 Step 2 Remove resivour and set aside 2 10mm nuts Attachment 21578 Attachment 21579 Step 3 Lossen up your belt and pull it off the alt Use your 3/8 ratchet and inset it into the tension or to do so Attachment 21580 I use a pipe for a little more leverage Attachment 21581 Attachment 21582 Step4 Locate the one you will be replacing Upper smooth one Attachment 21583 Upper ribbed one Attachment 21584 Lower smooth (the one I replaced) Attachment 21585 Step 5 unbolt old pully Mine was a 15mm Attachment 21586 Attachment 21587 Step 6 install new pully Attachment 21588 Attachment 21589 Step 7 Reinstall belt (See step 3 and reverse) Step 8 reinstall coolant resivour (see Step 2 and reverse) Step 9 shut the hood Step 10 pat yourself on the back for a job well done :thumbsup: |
