3800 belt tensioner replacement/coolant elbow replacement
10 Attachment(s)
Been meaning to wright this up for some time now, if I did sorry this may be a duplicate
My belt tensioner failed I replaced it and here is a guid of how I did, not only can this be used for tensioner replacement guide but coolant elbows aswell **your exact tool and socket sizes may very this is on my 2001 pace car Tools needed, 10mm,13mm(deep)15mm,16mm(deep) ratchet, pliers, Parts needed Tensioner assembly, coolant elbows, belt(if needed) Attachment 28664 **I also did my power steering pump at the same time ****great time to change the power steering fluid Step1: like any project remove negative from your battery, Step 2: Remove strut crossbar by removing the 4nuts that hold it into place, set side (If equipped if not skip to step:3) Attachment 28665 Step 3: Remove the belt from, using a ratchet and a 15mm socket, I also use a long pipe for a little extra leverage Attachment 28666 Step 4: Remove the brace that goes from the alt to a bracket Attachment 28665 Using a 15mm socket on the alt side Attachment 28668 And a 10mm on bracket side Attachment 28669 Step 5: remove the alternator Start with removing the power out wire using a 13mm Attachment 28670 Remove the top 2bolt from the altenator Attachment 28671 Remove the lower bolt from the alt Attachment 28672 Remove the plug from the back side of the alt Attachment 28673 |
6 Attachment(s)
Step 6:Remove the clamps and heart hoses
Attachment 28653 Attachment 28654 Step:7 remove the tensionor assembly by removing the 3bolts **please see first picture for bolt locations Attachment 28655 Step8 prep your new part for installation, Remove the connection for the coolant outlet to the hoses clean, check orings and place into new tensioner assembly Attachment 28656 Put new coolant elbows into tensioner (If using aluminum ones use antisieze on the engine side Attachment 28657 Step 10: Reverse the process for installation Attachment 28658 Than you for you time, I hope this can help! |
great write up but if all i want to do is replace the coolant elbows, do i still have to take the belt tensioner off or could i just remove the alternator?
Originally Posted by WImonteman
(Post 604856)
You may be able to get away with taking the lower bolt of the alt off and just leaving it bolted to the tentioner but will make things harder toine up when you put it back together
Good write up, I also jus changed ma tensioner a little while ago
Guys i need some help. On my tensioner where the heater hose is connected the bolt for the fitting sheared off. Im drilling it out but i need to know what size the bolt is or what size i can use for the hole. My dad said to try running it without a bolt but I dont trust leaving it open like that. Im not sire if i can get it from my work even tho i work for GM so i need to know what size it is just in case
Also the other bolt didnt break but when i tightened it down the bolt stopped but i could still move the hose up and down with plenty of room. Why is that? Is that normal?
Great write up Justin. :congrats: Just found out the SS, old TAZ63, is leaking at the plastic 90deg elbow. Your instructions will help assure I don't remove too much stuff.
