ZZP 1.0 relearn help!
Old Aug 12, 2012 | 07:48 PM
  #31
What's this relearn process you all speak of? I had no issues with a zzp pcm?
You didn't have to do the relearn?
Old Aug 12, 2012 | 07:58 PM
  #32
03SSLE's Avatar
Originally Posted by 03SSLE
(On for 11 minutes/Off for 10 seconds/On for 11 minutes/Off for 10 seconds/On for 11 minutes/Off for 10 seconds) then START the car.
You want to do a total of 3 On/Off cycles. After waiting 10 seconds for the 3rd time start the vehicle.
The PCM has to 'learn' the correlation between the key and the passlock sensor so a (security) relearn is needed.
Old Aug 12, 2012 | 08:12 PM
  #33
01 Monte SS's Avatar
I knew that, just curious as to why I didn't have to go through this with mine? Must not be a requirement for all of their PCMs?
Old Aug 12, 2012 | 09:08 PM
  #34
You can get lucky and not have to do it, but usually you have to. No harm done if you didn't have to do it though
Old Aug 12, 2012 | 09:09 PM
  #35
Crusader SS's Avatar
Tomorrow is Monday... I would contact them and clarify the process to the letter... It should never be this hard unless you got a dud!!!... Good luck and let us know...
Old Aug 21, 2012 | 04:57 PM
  #36
05TSMonte's Avatar
I ran into the same problem when I installed my ZZP PCM. No instructions came with it so I searched and found the answers on Intense-racing.com. I have since swapped out my zzp pcm for an overkill pcm. IMO it is so much better than the zzp pcm and the shift points are way better. Just look under intense's pcm page for the info and links.
Old Aug 21, 2012 | 10:04 PM
  #37
X2... A few of us on here have Will's tune and it is far superior...
Dam20735
Feb 5, 2013 04:51 AM
03SSLE
Oct 19, 2012 11:19 AM
adryan16
Sep 19, 2012 11:27 AM
BlaqkSouldier
Jul 19, 2011 05:02 PM
4ever3
Dec 21, 2009 10:40 AM
