-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   white smoke (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/white-smoke-232/)
85MonteSSwhite Mar 31, 2005 03:40 PM
white smoke
Ive noticed some whit smoke coming out of my tail pipe recently. My car is an 85 carbureted ss with a 305. It doesnt smell like anti freeze and my power is up to normal. someone told me im burning too lean. I was wondering if this was true and if so how do i git-er-fixed. Thankyou
Patrick Mar 31, 2005 04:19 PM
RE: white smoke
burning too lean wont make it smoke...is the engine stock? has it ever been apart??
benhillzone3 Apr 1, 2005 07:31 PM
RE: white smoke
what exacgtly is burnign lean? i never heard of that before
Patrick Apr 2, 2005 02:57 PM
RE: white smoke
burning lean means that in your air to fuel mixture, you have too much air, and not enough fuel.
85MonteSSwhite Apr 2, 2005 03:00 PM
RE: white smoke
yes it is stock and no i dont think it was ever apart
Patrick Apr 2, 2005 04:49 PM
RE: white smoke
as a motor gets to be older, one of the first things to go south is valve guide seals...that allows a tiny bit of oil into the combustion chambers, thus producing a bit of smoke. i would keep an eye on the oil level...if you dont already. also, have you felt any change in performance?
montejass Apr 5, 2005 12:10 PM
RE: white smoke
White smoke is generally an indicator that your burning off water somewhere in the combustion process.
I have a few ????? ..
Did this just start happening abruptly?
Is it smoking alot?
There is not much difference between a blue smoke which would be oil burn off and water which would be a little lighter.
Are you losing water from your cooling system?
If it were running too rich your smoke would be more on the black side.
TVW
montejass Apr 5, 2005 12:51 PM
RE: white smoke
Additionally, I would pull several if not all of your spark plugs for inspection.
Black/Dry: Running too rich.
Black/Wet: Burning oil
Wet/Rust: Water
TVW
benhillzone3 Apr 5, 2005 09:18 PM
RE: white smoke
In this forum you learn something everyday even if its not mc related
