-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   where is the connection for an oil pressure gauge? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/where-connection-oil-pressure-gauge-646/)
96_z34 Jul 17, 2005 07:53 PM
hey, i just got a gauge cluster for my 96 z34, i've got the engine temp and volt gauges working. but does anyone know where to make the connection for the oil pressure gauge?
[IMG]local://upfiles/392/779DA7F8333D4BFDA8BFA49CDD634741.jpg[/IMG]
Calculated Risk May 16, 2006 12:18 AM
RE: where is the connection for an oil pressure gauge?
Which Engine?
z34phoenix May 17, 2006 02:04 PM
the 96 Z34 has the LQ1 (3.4L DOHC)
to my knowledge, you would have the tap a new hole and rig it that way. i do not believe there is an existing place to tap into.
montejass May 17, 2006 10:45 PM
No oil sending unit on this motor?
Would it not have an oil dummy light hooked up to a sending unit somewhere to monitor oil pressure to kick off the dummy light?
