-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   what to look out for on a used S/C? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/what-look-out-used-s-c-36420/)
montego May 15, 2012 09:14 AM
I found a top swap kit for 300 bucks. says it came off an 02 with 100k+ miles
what do i have to watch out for when buying a used supercharger?
what about the head and intake?
I have an 05 120k will this fit?
ChibiBlackSheep May 15, 2012 09:31 AM
Make sure the coating on the rotors is still intact.
Make sure the coupler has no play in it.
Try to make sure the heads aren't cracked
Mr Grizzly Mint May 15, 2012 10:25 AM
Yours will work. mill the heads to make sure they fit right. While your at it do some work on intake. Some shops will redo internals of the M90 so You can look into that. Also Your car is non s/c so drop the boost a bit Cus you may get knock unless you drop the compression. But thats just me being overly cautious.
montego May 15, 2012 05:45 PM
he said the intake is machined so o shouldn't have to worry about that. How much should milling cost? What if sc.is in bad shape is it worth getting for a rebuild?
ChibiBlackSheep May 16, 2012 08:52 AM
with how cheap they are, i don't think it is worth a rebuild.
