Unkown Problem please help
I was driving down a road with a slight(very very slight) incline, the car was doing about 50 at 1800 to 2000 RPM when it started jumping and dropping rpm like a misfire. I have recently changed plugs, wire, all three coil packs and fuel filter. Please give me your input. all post will be taken into account.
What's the ride?
That is a shifting point to go into 4th gear, up an incline it can hold the transmission and act funky. Next time it happens, just ease off the gas for a second, then step on it again and it will downshift and make it up the hill no problem. It's common with these cars. A good tune for transmission line pressure and shift points would fix that. But it's nothing wrong. |
Cruise control will also cause it to act funny if it's trying to coast at the set speed, annoying enough that I take it off.
it is a 98 Monte Carlo LS. Well I'm sure the tranny fluid needs changing
thanks for the input |
